Cameras Are Not Detected in NI MAX After Updating to NI-PAL 2026 Q3
Updated Oct 27, 2026
  • Camera
  • NI-IMAQdx
  • NI-PAL
  • Vision Acquisition Software
I updated to NI-PAL 2026 Q3 (26.5), my cameras are no longer detected in NI Measurement & Automation Explorer (NI MAX).
The cameras previously appeared and functioned correctly in NI MAX, but after the update they no longer appear as available devices.
Because the cameras are not detected in NI MAX, they are also unavailable in LabVIEW.
This behavior can occur due to an incompatibility between NI-PAL 2026 Q3 (26.5) and NI-IMAQdx versions 19.5 and earlier.
NI‑IMAQdx is installed as part of NI Vision Acquisition Software and provides support for USB, GigE Vision, Camera Link, and other image acquisition devices.
If the system does not meet the requirements described in Verify NI-IMAQdx Compatibility Before Updating to NI-PAL 2026 Q3, camera detection issues may occur after updating to NI-PAL 26.5.4
To determine the installed NI-IMAQdx version and NI-PAL:
  1. Open NI MAX.
  2. Select My System.
  3. Expand Software.
  4. Locate NI-IMAQdx and NI-PAL in the software list.
  5. Select each component to view its installed version.
Compare the installed NI-IMAQdx version against Table 1 and follow the corresponding recommendation.
Table 1. Recommended actions based on the installed  NI-IMAQdx version
Installed NI-IMAQdx VersionCompatible With NI-PAL 26.5Recommended Action
19.5 or EarlierNoInstall a compatible software combination or restore previously working configuration.
20.0 or later YesVerify software compatibility with the installed LabVIEW version and confirm camera operation in NI MAX.
Note: NI-IMAQdx 20.0 removed support for IEEE 1394 (FireWire) cameras. Systems using FireWire cameras may need to remain on an earlier supported software combination to preserve functionality.
For systems running LabVIEW 2017 through LabVIEW 2020:
  1. Upgrade to Vision Acquisition Software 20.0 or later using NI Package Manager
  2. Verify that NI-IMAQdx 20.0 is installed in NI MAX or NI Package Manager.
  3. Confirm that the camera is detected in NI MAX.
For systems running LabVIEW 2014 through LabVIEW 2016:
NI- IMAQdx 20.0 does not support these LabVIEW versions.To restore functionality:
If possible:
  1. Move to the LabVIEW 2017 version or later
  2. Install Vision Acquisition Software 20.0 or a compatible version. Refer to the corresponding version in the  Vision Acquisition Software Release Notes.
Else:
Need to maintain a software combination that uses NI-IMAQdx 17.5 and a compatible NI-PAL version to restore camera detection:
  1. Remove all NI Software from the PC using NI Package Manager.
  2. Reinstall a previously functioning combination of NI-PAL and Vision Acquisition Software.
  3. Verify camera is detected in NI MAX.
Note: A documented downgrade process for NI-PAL component is not currently available. Restoring functionality may require reinstalling all the NI software in the previous working versions.
NI-IMAQdx is installed as part of NI Vision Acquisition Software and provides support for USB, GigE Vision, Camera Link, and other image acquisition devices.
Customers planning an upgrade after restoring functionality should review the article Verify NI-IMAQdx Compatibility Before Updating to NI-PAL 2026 Q3.
During the installation or upgrade of NI Vision Acquisition Software, components required to run LabVIEW applications can be omitted from the installation.
If camera detection has been restored but LabVIEW code that uses NI-IMAQdx functions does not execute correctly, verify that the appropriate NI-IMAQdx Support for LabVIEW package is installed for the LabVIEW version in use. Also verify that the installed support package matches the bitness of the LabVIEW installation.
For example, systems running LabVIEW 2018 (32-bit) should have NI-IMAQdx Support for LabVIEW 2018 (32-bit) installed.
If the NI-IMAQdx Support for LabVIEW package was not selected during the Vision Acquisition Software installation, it is not necessary to reinstall NI-IMAQdx, Vision Acquisition Software, or NI-PAL. Install the required package directly from the Packages tab in NI Package Manager.
After installation, verify that the application can access NI-IMAQdx functions and acquire images as expected.
