This behavior can occur due to an incompatibility between NI-PAL 2026 Q3 (26.5) and NI-IMAQdx versions 19.5 and earlier.
NI‑IMAQdx is installed as part of NI Vision Acquisition Software and provides support for USB, GigE Vision, Camera Link, and other image acquisition devices.
To determine the installed NI-IMAQdx version and NI-PAL:
- Open NI MAX.
- Select My System.
- Expand Software.
- Locate NI-IMAQdx and NI-PAL in the software list.
- Select each component to view its installed version.
Compare the installed NI-IMAQdx version against Table 1 and follow the corresponding recommendation.
Table 1. Recommended actions based on the installed NI-IMAQdx version| Installed NI-IMAQdx Version | Compatible With NI-PAL 26.5 | Recommended Action |
| 19.5 or Earlier | No | Install a compatible software combination or restore previously working configuration. |
| 20.0 or later | Yes | Verify software compatibility with the installed LabVIEW version and confirm camera operation in NI MAX. |
Note: NI-IMAQdx 20.0 removed support for IEEE 1394 (FireWire) cameras. Systems using FireWire cameras may need to remain on an earlier supported software combination to preserve functionality.
For systems running LabVIEW 2017 through LabVIEW 2020:
- Upgrade to Vision Acquisition Software 20.0 or later using NI Package Manager
- Verify that NI-IMAQdx 20.0 is installed in NI MAX or NI Package Manager.
- Confirm that the camera is detected in NI MAX.
For systems running LabVIEW 2014 through LabVIEW 2016:
NI- IMAQdx 20.0 does not support these LabVIEW versions.To restore functionality:
If possible:
- Move to the LabVIEW 2017 version or later
- Install Vision Acquisition Software 20.0 or a compatible version. Refer to the corresponding version in the Vision Acquisition Software Release Notes.
Else:
Need to maintain a software combination that uses NI-IMAQdx 17.5 and a compatible NI-PAL version to restore camera detection:
- Remove all NI Software from the PC using NI Package Manager.
- Reinstall a previously functioning combination of NI-PAL and Vision Acquisition Software.
- Verify camera is detected in NI MAX.
Note: A documented downgrade process for NI-PAL component is not currently available. Restoring functionality may require reinstalling all the NI software in the previous working versions.
