I am using NI-DCPower merged channels and debugging my application in the Digital Pattern Editor (DPE). After the channels are merged, I can run the application successfully, but DPE reports errors when I attempt to take control of, measure, or interact with any NI-DCPower resources during interactive debugging:
The error references a non-primary channel of a merge configuration, even when I'm attempting to control a DCPower channel that is not in the same session. The issue is reproducible when the primary and secondary channels participating in a merged-channel configuration are assigned to separate NI-DCPower sessions. In DPE, errors may occur when controlling any DCPower channels after the merge configuration is active.
