Update Systems Running NI-PAL Earlier Than 17.0 Before Security Patching
Updated Oct 30, 2026
  • NI-PAL
  • NI-PAL 2026 Q3
My system is running a version of NI-PAL earlier than 17.0, and I am concerned about whether the security patch can be applied successfully. I need to understand the recommended process for applying the security update and what actions to take if the update does not install correctly or if the system does not operate as expected after the update.
For systems running NI-PAL earlier than 17.0, the patch has not been validated, and successful operation cannot be guaranteed. To minimize risk, complete the following processes.
[+] 1. Applying the Patch
To apply the patch, follow these steps:
  1. Back up the system.
    • Create a complete system backup before making any changes.
    • Verify that the backup can be used to restore the previous configuration if necessary.
  2. Attempt to apply the security patch.
    • Apply the Windows security update to the system.
    • Be aware that NI-PAL versions earlier than 17.0 have not been validated with this patch.
  3. Verify system operation.
    • Confirm that the patch installed successfully.
    • Validate that all expected system functions operate normally.
[+] 2. System or Patch Installation Errors
If the patch cannot be installed successfully or the system does not operate as expected:
  1. Restore the previous configuration.
    • Use the backup created before applying the patch.
  2. Upgrade the software stack.
    • Upgrade to the latest supported software versions.
    • Alternatively, update at least one NI driver component to a version that includes NI-PAL 17.0 or later, such as NI-VISA 17.0, NI-DAQmx 17.0 or later.
  3. Validate the updated configuration.
    • Confirm that NI-PAL 17.0 or later is installed.
    • Verify that the system operates as expected after the upgrade.
  4. Apply the patch.
    • Reapply the security update after the updated configuration has been successfully validated.
