PXI Modules Are Not Recognized Correctly in NI MAX and FlexLogger Reports Trigger Line Errors
Updated Oct 22, 2026
  • PXIe-8301
  • PXI Remote Control Module
  • Thunderbolt Cable
  • FlexLogger
I have connected a host PC to an NI PXIe-1085 chassis using an NI PXIe-8301 remote control module over a Thunderbolt cable.
When attempting to acquire measurements across multiple PXIe modules in NI FlexLogger, the following error is displayed:
A registered trigger line could not be found between devices in the route. If using a PXI chassis, ensure that the chassis is correctly recognized and configured in MAX.
This error manifests only when acquiring data across multiple modules simultaneously; data acquisition completes without errors when running a single module alone.
When I checked the NI MAX, the installed PXIe modules and the PXIe-8301 controller do not show their correct model names or slot numbers properly; however, clicking the Refresh button in NI MAX or rebooting the PC and PXI chassis does not resolve the issue.
Delete the PXI configuration cache files (pxisys.ini and pxiesys.ini) from C:\Windows, then perform Tools >> Reset Configuration Data in NI MAX and reboot the PC. After restart, verify that the PXI chassis and modules are correctly recognized in NI MAX and Device Manager.
