This behavior is a confirmed software defect in NI Vehicle Communication Toolkit (VCOM) 2026 Q2.
As a workaround, configure the CAN FD frames before specifying custom bitrate values.
Open VCOMConfig.xml.
Leave Custom BitRate and Custom Data BitRate unspecified.
Open the configuration in NI VCOM System Explorer.
Select the required CAN FD frames in the signal tree.
Save the configuration.
Open VCOMConfig.xml in a text editor such as Notepad or Notepad++.
Manually add the desired custom bitrate values to the configuration file.
<BitRate>500000</BitRate>
<DataBitRate>2000000</DataBitRate>
<CustomBitRate>32A0041E07</CustomBitRate>
<CustomDataBitRate>800F00A0032E33</CustomDataBitRate>
Save the file, then deploy the VeriStand.
Using this workflow allows CAN FD frames with payload lengths greater than 8 bytes to be loaded normally while still using the desired custom bitrate settings.
