Why Can't I Use the 802.11 Application Framework in LabVIEW?
Updated Oct 26, 2026
  • LabVIEW Communications System Design Suite
I am trying to use the 802.11 Application Framework with LabVIEW 2025 or another standard LabVIEW version, but I cannot find, install, or run the framework. I expected the 802.11 Application Framework to be available in my LabVIEW environment, but the framework does not appear or cannot be executed.
The LabVIEW Communications 802.11 Application Framework requires LabVIEW Communications System Design Suite and cannot be used with standard LabVIEW development environments, such as LabVIEW 2026 or earlier.
To use the 802.11 Application Framework, install the supported version of LabVIEW Communications System Design Suite and activate the required licenses. For example, 802.11 Application Framework 2.5 requires LabVIEW Communications System Design Suite 2.1.
