Observe Output Voltage Transients Before Waveform Start on PXIe-5433
Updated Oct 21, 2026
  • PXIe-5433
  • NI-FGEN
I am using a NI PXIe-5433 Arbitrary Waveform Generator (AWG) to generate arbitrary waveforms. Before the waveform begins, I observe an unexpected voltage transient at the output.
The transient appears as a brief voltage spike or dip immediately before the intended waveform starts. The behavior occurs consistently before waveform generation. The waveform generation proceeds normally after the transient occurs.
To reduce or eliminate the observed transient:
  1. Prepend at least 8 bytes of zero-valued data to the beginning of the waveform.
  2. Avoid sharp waveform edges when possible.
  3. Avoid narrow pulses or abrupt signal transitions that may contribute to the transient behavior.
  4. Validate the waveform after modification to confirm that the transient is no longer present.
  5. If abrupt transitions are required by the application, evaluate alternative waveform implementations and verify performance under the intended operating conditions.
The transient is reproducible under specific waveform conditions and occurs before waveform generation begins. The waveform generation itself is not affected once the intended waveform starts.
