I am trying to use the SM.IInstrSessionMgr instance to get a handle to a remote GPIB device. I am able to use raw VISA read and write operations to make the connection, so the link to the remote PC is working correctly. However, the error returned through the session manager is:
'visa://<hostname>/<resource>' is not a driver session name
If I run the VI on the local computer directly connected to the GPIB device using only a local resource string (such as GPIB0::22::INSTR), the connection works as expected. The failure occurs when passing a remote VISA resource string directly into the session manager node without the expected prefix or mapping.
