When I launch TestStand from a custom TestStand Environment (.tsenv), the VeriStand Steps for TestStand appear in the Insertion Palette with internal names such as NI_VeriStand_Connect instead of their normal display names.
The following message appears:
String not found in the language resource files
If I launch TestStand normally, the VeriStand Steps load and display correctly. The issue only occurs when TestStand is launched through the custom environment.
