Controlling CFG Pin Voltage Programmatically on NI PXIe-1487
Updated Oct 22, 2026
  • PXIe-1487
  • FlexRIO
Can PXIe-1487 or other NI GMSL hardware programmatically control the physical voltage applied to the MAX96716A/MAX96717 CFG pins?
No. Current NI GMSL hardware does not support software control of the physical voltage applied to MAX96716A/MAX96717 CFG pins. On PXIe-1487, CFG pin voltages are not configurable during startup or runtime.
Support for configurable CFG pin strapping voltages may be considered in future products but is not available at this time.
