Updating Affected Systems to NI-PAL 2026 Q3 Using NI SystemLink™
Updated Oct 20, 2026
  • SystemLink
  • SystemLink Base
  • SystemLink Full
  • SystemLink Professional
  • SystemLink Enterprise
  • SystemLink Server
  • SystemLink Client
  • NI-PAL
In this article we are going to use NI SystemLink to update multiple affected systems to NI-PAL 2026 Q3.
Note: The below workflows require you have an active ni.com user account and have a System Maintainer (or equivalent) role on your SystemLink instance.
Click on the plus symbol to expand the sections of this article.
[+] SystemLink Base and Server 2026 Q3 and Prior
Download and verify the security update
  1. Download the NI-PAL-2026 Q3 offline installer from NI-PAL download page.
  2. Mount the .iso file by double clicking it in Windows File Explorer.
  3. In File Explorer, open the “pool” directory in the mounted disk and note the various .nipkg files required for the update.
Create a SystemLink Package Repository to host the security update
  1. In your web browser, navigate to your SystemLink deployment.
  2. Open the Package Repository application in the Systems Management section of the navigation pane.
  3. Press the Create button.
  4. Specify a Feed Name (e.g. NI-PAL 2026 Q3), Workspace, and set the Platform Type to Windows, then press the Create button.
    Note:
    Ensure the created feed is published to a workspace accessible by whomever will be completing the next section “Deploy the security update to your connected systems”
  5. Click the Configure button to open the newly created Package Repository.
  6. In the Package Repository details page, press the Add button in the Packages section.
  7.  Select Upload Packages option, and then press the Browse button to open the file selection dialog.
  8. Use the file selection dialog to navigate to the pool folder identified in step 3 of the Download and Verify section above to upload the .nipkg files and press Open.
  9.  Once all files are uploaded, press the Close button.
  1. Now that you have created your feed, open the Systems application in the Systems Management section of the navigation pane.
    1. In the Systems view, select Add Filter and choose Package and Version as the filter criteria.
    2. Build the query: "Package and Version" is less "ni-pal: 26.5.0".
  2. Select the systems you would like to update.
  3. Press the Software button in the toolbar menu.
  4. Select Feeds in the left side of the Software Installation window and press the Add button.
  5.  Choose Add from Package Repository in the Add Feeds dialog.
  6. Select your newly created Feed item and press Add.
  7.  Press the Apply button to register the Feed with the selected systems.
  8. Next, ensure NI Package Manager is updated to 2026 Q3 or later. In the Available section on the left side of the software installation window, check the Upgrades section for NI Package Manager. Select the appropriate Upgrade version and press Next, then Apply to install the upgrade.
    • Refer to the Related Links section to see an article about doing these processes with offline installers.
  9.  After upgrading NI Package Manager, Uncheck the Products Only and Check the Hidden items from the View dropdown.
  10. Use the Filter box to search for ni-pal and mark the package NI-PAL (infrastructure) for upgrade, then press Next.
  11.  Review the changes, then press Apply. A Software installation job will be sent to each system to apply the security update.
See Deploying Applications to Clients on a Server - SystemLink Server User Manual
[+] SystemLink Base/Full/Professional 2026-10 and later or SystemLink Enterprise
Create a SystemLink Feed to host the security update
  2. Open the Feeds application in the Systems Management section of the navigation pane.
  3. Press the Create feed button and specify a Name (e.g. NI-PAL 2026 Q3), Workspace, and set the Platform Type to Windows, then press the Create button.
    Note: Ensure the created feed is published to a workspace accessible by whomever will be completing the next section “Deploy the security update to your connected systems”.
  4. In Packages tab of the newly created feed, press the Add packages button. From Windows explorer, drag all the .nipkg files identified in the Download and Verify section above into the Upload dialog. Press OK.
  1. Now that we have created our feed, open the Systems application in the Systems Management section of the navigation pane.
  2. Ensure the systems you would like to update have NI Package Manager 2026 Q3 or later installed. Select the systems you intend to update, and press the Install software button.
  3. Select Registered feeds as the source and search for NI Package Manager, then press Next and then Install.
  4. Select the systems you would like to update and press the Install software button.
  5. Once the NIPM software upgrade has completed for your selected systems, we can install the NI-PAL update. With your systems selected, press Install Software again, then choose SystemLink feeds as a source, and search for your newly created feed. Select it and press Next.
  6. Ensure the checkbox for Install recommended packages and Automatically restart if required are checked, then press Install. A Software installation job will be sent to each system to apply the security update.
