Parameter Location for Only Display Latest Results in TestStand
Updated Oct 6, 2026
  • TestStand
I am customizing a report plug-in in NI TestStand and need to programmatically configure or access the setting behind the Only Display Latest Results option. Where is this property located in the TestStand model plug-in?
The Only Display Latest Results setting is specific to NI report generation and is located under the plug-in's specific options container:
PluginSpecific.Options.PurgeOnTheFlyResults
This setting is implemented within the default report generator architecture, sequence file location:
C:\Program Files\National Instruments\TestStand 20XX\Components\Models\ModelPlugins\NI_ReportGenerator.seq
