Machine Vision Tools Grayed Out in NI Vision Assistant
Updated Oct 6, 2026
  • Vision Assistant
  • Vision Development Module
When attempting to use machine vision tools—such as Pattern Matching, Geometric Matching, or Shape Detection in NI Vision Assistant, the menu items or processing steps are grayed out and cannot be selected. This occurs even when the NI Vision Development Module (VDM) is properly licensed and activated in NI License Manager.
In NI Vision Assistant, specific machine vision algorithms (such as Pattern Matching, Geometric Matching, and Shape Detection) are designed to operate on 8-bit grayscale (or binary) images. If a 32-bit color image (such as RGB or HSL) is opened, these functions are disabled by default because they cannot directly process multi-channel color data.
If you are using a 32-bit color image, the image must first be converted to an 8-bit grayscale image.
Once the 8-bit grayscale conversion step has been added to your Vision Assistant script, navigate back to the Machine Vision palette. The Pattern Matching, Geometric Matching, and Shape Detection steps will become active and available for use.
If your inspection requires matching based on color information rather than shape or grayscale texture, use the Color Matching or Color Pattern Matching steps located under Processing Functions: Color instead.
