Interfacing X4xx Series USRPs with PXIe Ethernet Modules
Updated Oct 5, 2026
  • Ettus USRP X410
  • Ettus USRP X420
  • Ettus USRP X440
  • Ethernet Device
I am intending to use a PXIe chassis (such as the PXIe-1095) with an embedded controller (such as the PXIe-8862) to interface with multiple Ettus USRP X4xx devices for a high-bandwidth streaming application. I want to know if there is a PXIe module that allows interfacing directly with the USRP X4xx over QSFP ports instead of using a standalone host PC with the Dual 100 Gigabit Ethernet PCIe Interface Kit.
To interface an Ettus USRP X4xx with a PXIe chassis and controller, use supported PXIe Ethernet modules or custom FPGA interface modules:
  1. PXIe Ethernet Modules (Standard Network Adapter Operation):
    • PXIe-8280: Provides a single QSFP28 port supporting data rates up to 50 Gb/s.
    • PXIe-8240: Provides dual QSFP+ ports supporting up to 40 Gb/s per port (80 Gb/s aggregate).
    • Install the required hardware drivers on the PXIe controller OS to recognize the module as a standard network adapter, configure the IP address, and communicate using USRP Hardware Driver (UHD) or NI-USRP.
    • An example of using the PXIe-8240 with the USRP X410 is shown in this GitHub example.
  2. PXIe FPGA Modules (Protocol Integration):
    • PXIe-7903 or PXIe-6594: Can interface with USRP X4xx devices in custom solutions integrating high-speed serial protocols (such as Aurora) via LabVIEW FPGA. Note that only the USPR X410 has support for LabVIEW FPGA
  3. External Host PC with PCIe Interface Kit (Alternative Architecture):
    • Connect the PXIe chassis to an external host PC via a MXI-Express controller/module, and install the Dual 100 Gigabit Ethernet PCIe Interface Kit (Part Number: 788216-01) in the host PC to achieve full 100 GbE throughput.
Note: Connecting via the rear iPass+ zHD port using a PXIe-8394 MXI module (used on USRP X410 for LabVIEW FPGA RIO targets) is not supported on the USRP X420 or X440.
Bandwidth Considerations
  • The PXIe-8862 controller provides a maximum system bandwidth of approximately 16 GB/s (128 Gb/s).
  • The controller is generally not the primary bandwidth bottleneck in this application.
  • Throughput is typically limited by the network interface module.
For the PXIe-8280:
  • Maximum theoretical throughput: 50 Gb/s.
  • Using SC16 I/Q data:
    • I = 16 bits
    • Q = 16 bits
    • Total = 32 bits/sample
  • Theoretical sample rate:
    50 Gb/s ÷ 32 bits/sample ≈ 1.56 GS/s
  • Considering Ethernet and protocol overhead, an achievable throughput close to 45 Gb/s is more realistic:
    45 Gb/s ÷ 32 bits/sample ≈ 1.4 GS/s
This throughput can support bandwidth requirements associated with the X4_1000 FPGA image for a single channel or multiple lower-rate channels, depending on the application.
FPGA Image Considerations
  • The PXIe-8240 and PXIe-8280 do not support native 100 GbE throughput.
  • FPGA image flavors requiring 100 GbE operation cannot be fully utilized through these PXIe Ethernet modules.
  • Applications will typically use FPGA image variants that operate within the available 40 Gb/s to 50 Gb/s interface limits, such as X4_400 or X4_1000, depending on bandwidth requirements.
The Dual 100 Gigabit Ethernet PCIe Interface Kit for Ettus USRP X4xx remains the preferred solution when full 100 GbE throughput is required. PXIe-based Ethernet adapters can provide successful connectivity and high-speed streaming but are limited by their supported Ethernet link rates and host interface bandwidth.
