sbrio-9629 Encrypted Envelope Error During Synthesis
Updated Oct 28, 2026
  • cRIO-9041
  • NI-9853
  • sbRIO-9626
  • LabVIEW Real-Time Module
  • LabVIEW FPGA Module
I am experiencing a compilation failure when trying to compile a LabVIEW FPGA VI on an sbRIO-9629 using the onboard CAN0 interface. The compilation fails during synthesis with the following error message.
ERROR: [Synth 8-5809] Error generated from encrypted envelope.
RTL Elaboration failed
synth_design failed
The code was previously developed on a cRIO-9041 controller using an NI 9853 C Series module, and I copy-and-pasted the code into an sbRIO project. The unchanged sbRIO onboard CAN shipping examples compile without error.
This issue occurs when code copied from a CompactRIO project retains the standard CAN frame cluster type definitions rather than the default CAN FD cluster type definitions required by the sbRIO-9629 onboard CAN interface.
To resolve the compilation failure:
  • Open the FPGA VI under the sbRIO-9629 target in the LabVIEW Project Explorer.
  • Identify and delete the cRIO CAN frame cluster type definitions that were copied into the block diagram.
  • Replace them with the default sbRIO-9629 CAN FD cluster type definitions.
  • Save the VI and compile the FPGA VI again.
