Enabling LabVIEW Project Access in the controller Startup Settings activates the service listening on TCP Port 3079. Specifically, this port is used by the LabVIEW Real-Time execution and deployment service to handle interactive VI execution, debugging, and deployment on the Real-Time (RT) target from the LabVIEW Project Explorer Window.
To verify the active TCP and UDP listening ports directly on the controller, refer to the steps below:
- Establish a Secure Shell (SSH) connection to the controller using an SSH client.
- Run the following command in the terminal to list all active listening ports: netstat -tuln
