When I execute a test sequence using a custom TestStand application or custom LabVIEW User Interface that writes numeric arrays or binary waveform data to a Microsoft SQL Server database, the following run-time error occurs:
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred executing a statement.
Schema: SQL Server Stored Proc (NI)
Statement: PROP_BINARY
Description: Arithmetic result exceeded 32 bits.
Number: -2147024362
NativeError: -2147024362
Source: TSDBLog
ERROR CODE: -2147024362; Code Module/User-defined error code.
LOCATION: Step 'Log Results to Database' of sequence 'LogToDatabase' in 'NI_DatabaseLogger.seq'
Additionally, the same sequence file executes without errors when run directly inside the TestStand Sequence Editor. f a rebuilt DBLog.dll is missing or not registered in the runtime path, TestStand may also return Error -17502: System Level Exception at step Create Server for Non-OTF.
