After installing LabVIEW 2026 Q3 Patch 1 (26.3.1) on a system that already has both the 32-bit and 64-bit editions of LabVIEW 2026 Q3 installed, Application Builder fails while building an installer and displays the following error:
Error 7 occurred at CDK_Utility_GenerateErrorCluster.vi ->IB_MSI.lvclass:Engine_Build.vi
Error Message: LabVIEW cannot locate the source installer for a component necessary to build this installer. LabVIEW last located the missing component in the following distribution:
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
