Connect to and Remove Multiple Volume License Servers in NI License Manager
Updated Nov 2, 2026
  • Volume License Manager
  • License Manager
I need to connect NI License Manager to multiple Volume License Servers. I also need to remove one or more existing server connections, but the server information remains displayed or the connection is not removed as expected.
To manage multiple server connections in NI License Manager, use the following methods.
Connect to Multiple Volume License Servers
  1. Open NI License Manager.
  2. Select Manage Volume License Servers from the menu.
  3. Enter the server addresses and separate multiple entries with a comma.
    • Example: server1:27000, server2:27000
  4. Select OK.
Remove One or More Server Connections
  1. Open Manage Volume License Servers.
  2. Delete the server address that should no longer be used.
  3. Select OK.
If the server connection remains after removing the address, the following method will remove all server connections in NI License Manager:
  1. Close NI License Manager.
  2. Navigate to: C:\ProgramData\National Instruments\License Manager\Data
  3. Delete the following files:
    • servers.ini
    • Licensing.dat
  4. Reopen NI License Manager. The files should be regenerated automatically without previously saved custom server entries.
  5. Verify that no servers are listed on the network licensing page.
  6. Reconfigure the desired server connections through Manage Volume License Servers.
If the server connection still appears after deleting the files, verify whether a licensing environment variable is configured on the computer. An environment variable can override local NI License Manager settings and automatically populate server information. Refer to the Using Environment Variables to Point to a NI-VLM or FlexLM Server article for additional details.
Deleting servers.ini and Licensing.dat resets locally stored NI License Manager server configuration information. NI License Manager recreates these files when the application is launched again.
