NI-FBUS 16.0 officially supports only 32-bit LabVIEW 2013, 2014, 2015, and 2016. If your application depends on NI-FBUS VIs, run the application in a supported LabVIEW version.
Down save custom application code
- Open your custom application code in LabVIEW 2025/2026.
- Select File>>Save for Previous Version... and save a copy targeting LabVIEW 2016.
- Do not modify or copy
NIFB.llb or other NI-FBUS driver libraries.
NIFB.llb is an internal NI library.- The library is password-protected by design.
- NI does not provide unlocked versions of protected driver libraries.
- Remove incompatible LabVIEW versions
- Uninstall LabVIEW 2025 and LabVIEW 2026 temporarily from the computer.
- Reinstall driver support for LabVIEW 2016
- Uninstall the NI-FBUS 16.0 driver.
- Verify that 32-bit LabVIEW 2016 is installed on the computer.
- Reinstall NI-FBUS 16.0. The installer will detect 32-bit LabVIEW 2016 and place the required driver files and palettes in the LabVIEW 2016 directory.
- Verify in LabVIEW 2016
- Open 32-bit LabVIEW 2016 and confirm that the NI-FBUS functions appear on the palette and execute as expected.
- Open the down saved copy of your custom VIs in LabVIEW 2016.
- (Optional) Reinstall newer LabVIEW versions
- You can now reinstall LabVIEW 2025 or 2026. This will not remove or overwrite the NI-FBUS driver integration already established in LabVIEW 2016.
Alternative Configuration:
Use separate development environments:
- Fieldbus System: 32-bit LabVIEW 2016 with NI-FBUS 16.0 installed.
- Development System: LabVIEW 2025 or LabVIEW 2026 for non-FBUS development. Down save custom code before transferring it to the NI-FBUS system.
