The PXIe-6569 Socketed CLIP resources are packaged with the PXIe-6569 sample projects and are not automatically installed in a location that is discoverable by newly created FPGA projects.
To make the PXIe-6569 Socketed CLIP available in a custom project:
Locate the PXIe-6569 sample project directory:
C:\Program Files\NI\LVAddons\flexrioii\1\ProjectTemplates\Source\FlexRIO\NI6569\
Copy the Socketed CLIPs folder from the sample project directory.
Paste the Socketed CLIPs folder into the same directory as the .lvproj file.
Open the LabVIEW FPGA project.
Open the IO Module Socket Properties configuration page.
Select the desired PXIe-6569 Socketed CLIP.
Recompile the FPGA VI if required.
R&D validated this workflow and confirmed that the Socketed CLIP can be successfully selected and used within a custom FPGA project after the resources are copied locally.
Additionally, R&D confirmed the following:
- The Getting Started FlexRIO Integrated IO.vi template is not required for PXIe-6569 development.
- All functionality provided by the sample project can be recreated in a custom LabVIEW FPGA project.
- The sample project primarily serves as a reference implementation.
- No unique initialization or configuration steps are performed by the sample project that cannot be implemented manually.
