The NI C Series modules and the CompactRIO platform are rated and validated for up to 5 grms random vibration (10 Hz to 500 Hz). Operating the hardware beyond these specifications can increase the risk of mechanical and connector-related failures.
To reduce connector and pin damage in high-vibration applications, implement the following design practices:
- Construct rigid cable support structures. Install solid support brackets or framing near the front of the NI C Series module to minimize cable movement and reduce mechanical loads on the connector interface.
- Secure front-panel cabling. Use cable ties or cable clamps to prevent cables from resonating, whipping, or transmitting excessive forces to the module during operation.
- Use custom backshells. Implement strain-relief backshells on connected cables to reduce leverage and mechanical stress applied directly to the connector pins.
If the application requires vibration performance beyond the NI C Series specification, consider migrating to NI FieldDAQ™ hardware. NI FieldDAQ devices are rated for up to 10 grms random vibration and use M12 industrial connectors designed for harsh operating environments.
