Which Licenses Are Required to Build USRP X310 FPGA Image
Updated Sep 14, 2026
I want to build USRP X310 core FPGA image using RFNoC configuration file. What licenses do I need to successfully complete the build?
For building USRP X310 standard FPGA image AMD Xilinx Vivado license is required. There is no need to purchase any additional intellectual property (IP) licenses.
Following AMX Xilinx software with corresponding versions should be installed on build machine:
  1. Xilinx Vivado ML Enterprise 2021.1
  2. AR76780 Patch for Vivado 2021.1
