The observed discrepancy is expected behavior and results from the opposing pin-numbering conventions used on the mating connectors of the NI PXIe-4304 module and the NI TB-4304 terminal block.
The PXIe-4304 front connector numbering begins with Row 32 at the top of the module connector. The TB-4304 printed circuit board (PCB) silkscreen numbering begins with Row 1 at the top of the terminal block connector. Because the connectors mate face-to-face, the connector rows are mirrored when connected. For example:
- Pin 1 on one connector mates with Pin 32 on the opposing connector.
- Pin 2 on one connector mates with Pin 31 on the opposing connector.
- Pin 3 on one connector mates with Pin 30 on the opposing connector.
To verify and connect signals correctly:
- Do not use the connector row-number silkscreen on the TB-4304 connector to determine signal locations.
- Reference Table 2-1, Front Connector Signal Pin Assignments in the NI PXIe-4304/4305 User Manual to identify the signal assignments on the PXIe-4304 connector.
- Follow the signal labels printed adjacent to the TB-4304 screw terminals, such as AI0+, AI0-, and AIGND, when making wiring connections.
