You can connect an NI Linux Real-Time target, such as a CompactRIO controller, to SystemLink even when it is initially connected directly to a host PC. However, the target must have a valid network path to the SystemLink Server. If the host PC uses separate network adapters for the local CompactRIO connection and the corporate network connection, the target may be unable to communicate with the SystemLink Server and may not appear in SystemLink or register successfully.
This article is intended for engineers configuring NI Linux Real-Time targets with SystemLink.
