USB-6451/3 Device Pinout for Counter/Timer Signal
Updated Sep 28, 2026
  • USB-6451
  • USB-6453
  • According to the USB 6451 or USB-6453 specifications, I was unable to find a detailed pinout specifically for the counter inputs. Could you please advise which pins are assigned to the encoder Source, Gate, A, B, and Z (Index) signals?
  • Is there any documentation that identifies which USB-6451 or USB-6453  connector pins correspond to the counter signals, similar to the pinout information available for X Series devices?
For most NI DAQ devices, the counter/timer signal assignments to the PFI lines are generally the same. The primary difference is the physical connector pin number associated with each PFI line. The table below summarizes the counter terminal mappings for the USB-6451 and/or USB-6453.
Counter/Timer SignalTerminal NameDefault Pin Number
CTR 0 SRCPFI 88
CTR 0 GATEPFI 99
CTR 0 AUXPFI 1011
CTR 0 OUTPFI 1214
CTR 0 APFI 88
CTR 0 ZPFI 99
CTR 0 BPFI 1011
CTR 1 SRCPFI 329
CTR 1 GATEPFI 431
CTR 1 AUXPFI 1112
CTR 1 OUTPFI 1315
CTR 1 APFI 329
CTR 1 ZPFI 431
CTR 1 BPFI 1112
CTR 2 SRCPFI 025
CTR 2 GATEPFI 126
CTR 2 AUXPFI 228
CTR 2 OUTPFI 1417
CTR 2 APFI 025
CTR 2 ZPFI 126
CTR 2 BPFI 228
CTR 3 SRCPFI 532
CTR 3 GATEPFI 634
CTR 3 AUXPFI 735
CTR 3 OUTPFI 1518
CTR 3 APFI 532
CTR 3 ZPFI 634
CTR 3 BPFI 735
FREQ OUTPFI 1417
