A PXI(e) module can pass through a standard airport security X-ray scanner used for carry-on luggage without being damaged or having its contents wiped. The airport scanner itself is generally not the primary concern during transportation.
The primary risks during travel are:
- Electrostatic discharge (ESD)
- Physical impact or connector damage
To help protect the PXI(e) module during transport:
- Place the module in an ESD-shielding or antistatic bag.
- Use the original NI packaging whenever available.
- Place the protected module in a padded rigid case or a well-cushioned carry-on bag if the original packaging is not available.
- Handle the module by the card edges or front bracket only.
- Avoid touching the backplane connector or exposed circuitry.
This handling approach is similar to transporting a laptop through airport security. PXI systems and modules are commonly transported through airport security screening when properly protected from ESD and mechanical damage.
