When initializing USRP X440 with new master clock rate the following error occurs:
[ERROR] [RPC] ADC tiles failed to sync properly.
The issue is caused by USRP X440 ADC hardware failure. Due to ADC implementation specifics, there are 4 tiles which need to be synchronized. Absence of synchronization will cause lowered spurious free dynamic range (SFDR) performance.To fix the issue hardware repair at NI service center is recommended.
