Configure Static IP Address Using NI MAX
- Connect the cRIO controller to the host computer through ethernet or USB (if supported by your device).
- Launch NI MAX.
- Expand Remote Systems and select your cRIO target.
- On the right side of the window, click on the Network Settings tab.
- For the Ethernet Adapter eth0 (Primary) change the Configure IPv4 Address option to Static. Enter the desired IP Address (e.g., 192.168.2.1), Subnet Mask, Gateway, and DNS server (if required).
- Click Save to store the network configuration.
Configure a Static IP Address Using NI Hardware Manager
- Launch the NI Hardware Manager.
- Select the cRIO for which you want to change the IP address.
- On the right side of the window, locate the Identity section and click the edit button next to the IP address.
- Click Configure network settings... to access the controller's network configuration.
- Select Ethernet adapter eht0 from the list and change the IPv4 request mode option to Static. Enter the desired IP Address (e.g., 192.168.2.1), Subnet Mask, Gateway, and DNS server (if required).
- Click OK to store the new network configuration.
If the controller becomes unreachable after changing the IP settings, verify that the host computer is configured on the same subnet as the new cRIO address. To verify this information, refer to the steps below:
- Navigate to Control Panel >> Network and Internet >> Network and Sharing Center >> Change adapter settings.
- Right-click the ethernet adapter that communicates with the cRIO controller and select Properties.
- Select the Internet Protocol Version 4 (TCP/IPv4) option from the list and click Properties.
- Select the Use the following IP address option and update the IP address, subnet mask, and default gateway (if required), so that the host PC is on the same subnet as the cRIO controller. For example, if the cRIO has an IP address of 192.168.2.1 and a subnet mask of 255.255.255.0, you can configure the host PC with an IP address of 192.168.2.2 and a subnet mask of 255.255.255.0.
- Click OK to update the network configuration.
