I am using an NI USRP-2954 to generate RF signals and have observed FM noise or ripple-like modulation near the noise floor during radar test set evaluations. The issue is visible even when transmitting a pure sinusoidal tone and after reducing RF gain to avoid clipping. The behavior appears consistently across test conditions and impacts FM noise measurements. I would like to improve the noise performance and determine whether the observed effects originate from the radio configuration, synthesizer behavior, digital signal chain, or another portion of the transmit path.
