Nigel™ AI LabVIEW Code Generation Takes Too Long or Fails
Updated Aug 26, 2026
  • Nigel AI Integration
Nigel AI is taking much longer to generate LabVIEW code than it did for similar kinds of requests previously.
Nigel provides a failure message in the chat when I try to use it to generate code. Nigel may say something like “LabVIEW Coding Agent tool failed...” but as this is an LLM generated response, the exact wording will vary.
This is a known issue that NI is currently working to resolve.
As a workaround, set the Nigel setting “Allow Stored Output” to False/Off.
You can do this by going to the menu. Then choose More>Settings> Allowed Stored Output.
To confirm this is the error you are encountering you can check the log files for a HTTP 400 error.
  1.  Navigate to the log files located at %programdata%\National Instruments\AIAssistants\Logs
  2. Find the most recent log file and search for the following message:
    • ClientResultException: HTTP 400 (invalid_request_error: previous_response_not_found)
If you do not see this error or if the above steps do not resolve the issue, please create a Technical Support case or contact Technical Support at +1 866 275 6964. When contacting Support, please have the log file ready.
