- Add the VCOM custom device in VeriStand. Click Create VCOM Descriptor to open the RBSConfig tool.
- Right-click in the Datapool, then select New Network>>CAN or FlexRay Network>>Create single network to add the database file.
- Find the checksum signal in the Datapool, then right-click on it and select Copy2Config.
- Find the checksum signal in the Configuration menu, then click it and choose Change to AutoSignal.
- In the drop-down menu of Auto Signal type, select ChecksumUserJ1850.
- CRCMask: Determine the data bytes that are used for the CRC calculation. For example, CRCMask 254(1111 1110 in binary) means that byte 1 to byte 7 of data bytes will be used for checksum calculation.
- Initial Value: CRC initial value. Default value is 255. For E2E Profile 2, it should be 255.
- FinalXORValue: XOR value at the end of the CRC algorithm. Default value is 255. For E2E Profile 2, it should be 255.
- UserByteBefore: These bytes are used before the data bytes for the checksum calculation. Leave it empty for E2E Profile 2.
- UserByteAfter: These bytes are used after the data bytes for the checksum calculation. Data ID list of E2E Profile 2 can be filled here.
Fill the above parameters as follows, then click Execute.
- Click the checksum signal in Auto Signals. In the Details, delete the elements in ChecksumUserBytesBefore by click the three points on the right side, then clicking Remove.
- Click the three points on the right side of ChecksumUserBytesAfter to edit the Data ID list.
For example, the Data ID list of this frame is [11, 22, 33, 44, 55, 66, 77, 88, 99, 110, 120, 130, 140, 150, 160, 170]. You should fill the ChecksumUserBytesAfter as follows.
- Right-click on the database file in Configuration, then select Save as XML to save the configuration.
There is a known issue about the value of CRCMask. A workaround is provided, please refer to Implementing Checksum Algorithm E2E Profile 5 with NI VCOM RBS Descriptor Tool.
