Question 1: Can NI change the calibration results after external calibration?
Answer: No. Calibration results represent the actual measured data obtained from testing the hardware against defined limits during the calibration process and cannot be arbitrarily edited or altered.
Question 2: Can I request to add test points in a Calibration Certificate?
Answer: Not as part of a standard request. Standard calibration procedures in Calibration Executive (CalExec) do not support specifying custom test points or custom test limits.
Question 3: Can the certificate be amended?
Answer: It depends on what content to be amended.
Standard Data/Results: Certificate data is generated directly from the automated or manual test run results and cannot be manually modified after completion.
Custom Calibration Due Dates: If a customer requires a specific calibration due date or interval other than the standard recommended date, this request must be specified prior to service when submitting the calibration request.
Customer Name: If a customer requires a specific customer name in calibration certificate, the request must be specified prior to service when submitting the calibration request.
