*** Assembly Binder Log Entry (MM/DD/YYYY @ HH:MM:SS) ***
The operation failed.
Bind result: hr = 0x80070002. The system cannot find the file specified.
Assembly manager loaded from: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
Running under executable:C:\Program Files\National Instruments\LabVIEW 20XX\LabVIEW.exe
--- A detailed error log follows.
=== Pre-bind state information ===
LOG: DisplayName = Example.Dependency, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0123456789abcdef (Fully-specified)
LOG: Appbase = file:///C:/Example/Application/
LOG: Initial PrivatePath = Dependencies
LOG: Dynamic Base = NULL
LOG: Cache Base = NULL
LOG: AppName = Example.lvproj for Run
Calling assembly: Example.CallingAssembly,Version=1.0.0.0,Culture=neutral,PublicKeyToken=null.
LOG: This bind starts in default load context.
LOG: No application configuration file was found.
LOG: Using machine configuration file from:C:\Windows\Microsoft.NET\Framework64\v4.0.30319\config\machine.config
LOG: Post-policy reference:Example.Dependency,Version=4.0.0.0,Culture=neutral,PublicKeyToken=0123456789abcdef
LOG: GAC Lookup was unsuccessful.
LOG: Attempting download of new URLfile:///C:/Example/Application/Example.Dependency.DLL.
LOG: Attempting download of new URLfile:///C:/Example/Application/Dependencies/Example.Dependency.DLL.
LOG: Attempting download of new URLfile:///C:/Example/Application/Example.Dependency.EXE.
LOG: All probing URLs attempted and failed.
