Method 1: Search for .NET Constructor Nodes
Use the Find dialog to locate all .NET Constructor Nodes within the VI.
- Open the VI.
- Press Ctrl+F to open the Find dialog.
- Set Search for to Objects.
- Select .NET Constructor Node.
- Run the search.
- Review the search results to identify all locations where .NET objects are instantiated.
Method 2: Identify VIs That Use .NET Properties
- Use Nigel to locate VIs that contain .NET properties.
- Review the results to identify the VIs which use .NET properties.
Note: Nigel is supported in LabVIEW beginning with version 2025 Q3.
