Reduce High Temperature Conditions in NI PXI Chassis
Updated Oct 15, 2026
  • PXIe-1095
  • PXIe-1081
  • PXIe-1084
  • PXIe-1085
  • PXIe-1092
  • PXIe-1088
  • PXI-1044
I observe that my chassis is overheating, and the temperature is very high during operation. I am concerned about the chassis temperature and want to prevent overheating from occurring.
To help prevent overheating conditions in the chassis, perform the following actions:
  1. Configure the chassis cooling profile.
    • Open NI Hardware Manager.
    • Select the chassis or module configuration.
    • Set Mode to High.
    • Configure the appropriate cooling profile according to the chassis requirements.
  2. Alternatively, you can also configure the fan settings in NI MAX.
    • Open NI Measurement & Automation Explorer (NI MAX).
    • Select the chassis.
    • Navigate to the Fans tab.
    • Set Mode to High.
  3. Operate the chassis within the specified temperature range.
    • Verify that the ambient operating temperature complies with the chassis specifications.
    • Review the hardware specifications document for the supported operating temperature limits.
  4. Remove dust and airflow obstructions.
    • Inspect the chassis fan inlets and outlets for dust accumulation or blockages.
    • Use an air duster to remove dust from the fans and ventilation areas.
    • Ensure adequate airflow around the chassis during operation.
Operating a chassis beyond its specified environmental limits or with restricted airflow may result in elevated temperatures and reduced cooling performance.
