The issue may be caused by a corrupted driver installation or an InstrumentStudio installation issue. Perform the following steps in order, starting with the least disruptive action:
Repair the affected drivers:
Launch InstrumentStudio and verify whether the Soft Front Panel opens successfully.
- Repair NI InstrumentStudio if the issue persists.
Install and reinstall the software in the correct order if the repair actions do not resolve the issue:
- Uninstall NI InstrumentStudio.
- Uninstall the affected drivers.
- Reboot the system.
- Install the required drivers.
- Install NI InstrumentStudio.
Launch the Soft Front Panel in InstrumentStudio and verify normal operation.
