After unreserving and re-reserving a cDAQ-9189 network device in NI MAX, an unexpected message appeared when running a Self-Test, displaying the message:
You do not have permission to save the settings. A login dialog box appears when attempting to save.
Logging in with the admin account allows the Self-Test to complete successfully. Other than this authentication prompt, the device functions normally, and similar behavior is not observed on other cDAQ network chassis.
