In VeriStand 2024 Q4 and earlier versions, users can use the keyboard shortcut Ctrl+A in the Mapping window to select all mapping channels.
Starting with VeriStand 2025 Q1 and continuing versions, the Ctrl+A shortcut no longer selects all mapping channels in the Mapping window. Users may observe that pressing Ctrl+A has no effect on the channel selection, leading to the assumption that the "Select All" functionality is no longer available.
This behavior is expected and is due to a change in the keyboard shortcut assignment for the Mapping window in newer VeriStand releases.
