Unable to Boot USRP X410 via eMMC
Updated Jul 15, 2026
  • Ettus USRP X410
I have a USRP X410 and I am unable to get the device to boot properly. I am able to connect to it via USB to access the embedded controller and power cycle the device, but no other interface connection works. How can I reboot the X410 back into a functioning state?
If you are unable to boot the X410 from eMMC, it is possible to boot the device into u-boot over JTAG. The will allow the filesystem to be reflashed from eMMC.
To do this, follow the process described in the Booting X4x0 over JTAG section of the X410 UHD Manual. This process requires you to use either the Xilinx SDK or the freely available Vivado Lab Edition.
