R&D has identified this issue as Bug #3883133. This bug appears in recent TestStand versions (from TestStand 2024 Q4 to TestStand 2026 Q3). This bug is fixed for the upcoming TestStand 2027 Q1 release.
To work around this issue for the affected versions, you can add a new .NET Action step before the PropertyLoader step. This .NET Action step, titled "Explicitly Load PropertyLoader Plugins", is included in the sequence file attached to this article. This step ensures the required assembly is loaded correctly and resolves the issue in both the Sequence Editor and the C# UI.
