I am using a PXI or PXIe system with a digital multimeter (DMM) and a switch module to perform scan-based measurements.
When I run a scan list (for example, path1; path2;), I see the same measurement value for multiple paths instead of different expected values.
If I modify the trigger configuration or attempt to use handshaking, I receive timeout errors such as:
Max Time exceeded before operation completed. Error code: -1074126845
This issue occurs consistently in a PXIe system, even though the same application works correctly in a previous PXI setup.
