The example application rfnoc_replay.grc located in /gr-uhd/examples/grc/ directory in GNU Radio 3.11 has missing "uhd_msg_push_button" blocks.
This is a known issue. The bug fix is tracked in the following link: uhd: cmake: Fix PyQt5 module check by mbr0wn · Pull Request #8153 · gnuradio/gnuradioThe current workaround for this issue is adding additional -DPYQT5_FOUND=ON flag when building GNU Radio from source.
-DPYQT5_FOUND=ON
Example Command:
cmake .. -DPYQT5_FOUND=ON <other flags>
