This article explains how to resolve the FPGA compilation error that can occur when compiling Aurora example projects for NI High-Speed Serial (HSS) devices, including the NI PXIe-6592R, NI PXIe-6591R, and NI PXIe-7902R, in LabVIEW FPGA 2023 Q3 or later.You may encounter this issue while generating intermediate FPGA files or building a bitfile. The compilation stops during VHDL generation before the Vivado compilation stage starts and displays the following error:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Set Permissions in 659XR_GenerateVHDL.vi:3340001
-> niFpgaTopLevelGenCallTargetSpecificVI.vi
-> niFpgaHandleConstraintsAndMiscFPGAFiles.vi
-> niLvFpgaTopModGen.vi
-> niLvFpgaTopModGen.vi.ProxyCaller
This procedure applies to systems using NI High Speed Serial Instruments Driver (nihss) 2023 Q3 or later.
