When you use RFmx Spectrum Analyzer measuring some spectrum measurements , like SEM ,ALCR , CHP or OBW ,etc , you also want to enable the "Max Hold" feature . When you check the setting parameters of RFmx Spectrum Analyzer , you could only find "Max" selection for Averaging Type, like below picture :
Is it same as "Max Hold" feature ? Does RFmx SpecAn support "Max Hold" feature ?
