I am able to successfully connect to the RTG system when using localhost for the ServerIP and using the NI-RTG Local API class in the RTG configuration INI file, but the connection fails when I switch to using the server’s IP address to use for the gRPC connection. The issue only occurs when replacing localhost with the server IP in my setup.
