No Signal Output of NI Daq Task
Updated Jul 15, 2026
  • Multifunction I/O Device
I am not seeing any voltage output when I run my application for the first time after boot. The task executes without errors, but there is no signal visible on the oscilloscope. If I rerun the application or make adjustments, the output may appear later. This behavior occurs consistently on the first boot.
This behavior can be caused by incorrect measurement setup or task execution conflicts.
Follow the steps below to isolate and resolve the issue:
  1. Verify oscilloscope probe configuration.
    • Ensure the oscilloscope probe is properly connected to the correct signal and ground.
    • Confirm the probe attenuation setting (for example, 1X or 10X) matches the oscilloscope channel configuration.
    • Check that the probe is functioning properly by measuring a known signal.
  2. Validate measurement method.
    • Confirm that the signal being measured is referenced correctly (for example, ensure proper grounding or differential measurement if required).
    • Use an alternative measurement tool, such as a Digital Multimeter (DMM) to confirm whether voltage is present at the output.
  3. Check for parallel task execution.
    • Ensure that no additional DAQmx tasks are running simultaneously that could interfere with the output task.
    • Stop or remove any parallel tasks that may be reserving the same hardware resources.
    • Verify that the task execution order is correct, especially when using multiple tasks within the application.
  4. Restart and reinitialize the system.
    • Reboot the system and run only the required task to confirm correct behavior.
    • Initialize hardware explicitly before starting the task.
Incorrect oscilloscope probe setup or grounding can prevent accurate signal detection, even when the system is functioning correctly. Additionally, running multiple DAQmx tasks in parallel may limit hardware resource availability, preventing proper signal generation during initial execution.
