The easiest way to stream video over RTSP to be viewed in LabVIEW is to call VLC's DLLs using ActiveX. This DLL is automatically installed on your system when you install VLC. Some examples of how to create and control the VLC instance within LabVIEW are provided below in the Related Links section. And you can see the attached VLC ActiveX Demo VI created via LabVIEW 2026 Q1 64-bit as an example of real-time streaming with VLC DLL and ActiveX.
