1. Ensure that the UHD driver version of host PC is greater than or equal to 4.9.0;
2. After upgrading the host PC to UHD 4.9.0, the X310+OBX needs to be refreshed the latest FPGA image using the uhd_image_loader command;
3. Send uhd_usrp_probe to verify if the host PC and USRP software driver versions are consistent; If no error is returned after running the command, you can run the example code in the open source environment;
